Center console collapse repair
Lakewood ranger
Pa
XLT FX4
Hi,
Can you share success with repairing the collapsed center console lid. 2003 Ranger extended cab. Collapsed right where your elbow presses down getting into the seat.
I have it apart and was considering some fiberglass tent poles cut to fit tight then epoxied in place.
any thoughts or other suggested approach?
Thanks in advance
Lakewood Ranger
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
My dad had this problem in his F-150. He used really thin plywood, cut to the shape of the bottom of the lid, and epoxied it place. Eventually he got a better on out of a Navigator. It didn't fit perfect, but was better than the broken one.
Lakewood ranger
Pa
XLT FX4
thanks, I'll give it a try
35
St. Petersburg
Multiple
Rangers
stock
stock
stock
I don't subscribe to causes that are compelled by irrational fears.
I don't know if I have the same one as you, I have the thick padded armrest that hinges up to a comparement underneath with a solid plastic lid. My pop broke the armrest hinge and pad then tried to fix it with JB Weld. It held for about a week, then broke again.
I looked at adding a plate to bolster the pad surface from underneath, but ultimately decided to just get a new one on ebay to the cost of about $80. in addition to the pad surface, about 1/3 of the screw tabs used to secure the pad to the armrest had broken and fallen off. I thought it was worth the extra money to just replace the broken part instead of attempting a second repair. I also replaced the armest and hinge with the dorman kit that uses a steel plate instead of the ribbed plastic one. It's considerably beefier and won't fracture when twisted like the plastic plate does due to not having tortional reinforcement ribs.
Lakewood ranger
Pa
XLT FX4
Thanks this is helpful.
