RustedRanger
- Mar 25, 2009
- 5
- Farmland IN
- Ford
- Engine Size
- 2.9L
The other day it got hot outside and as I was waiting in line to take in scrap metal my Ranger started getting hot,not boiling over but enough to make the idle rough. I removed the grill first then took some 1/2" fiberglass backed foam insulation I had laying around and with some quick measurements I pieced the insulation in around the outside of the radiator to fill in the huge gaps so that most of the air from the grill only goes through the radiator,not around it. If your careful it almost holds itself in place,I only needed a couple plastic zip ties and some duct tape. My Ranger don't have AC so it doesn't have a shroud so I figured the fan was pulling some air from the gaps around the radiator. All I have is the stock temp gauge but it seems to be running cooler. I was able to seal the bottom and sides of the radiator to the core support,if I had some sheet aluminum I could've sealed the top also. I don't know if regular unbacked foam would work or not...I don't think it would get hot enough to melt it. I also plan on getting some of the aluminum duct tape and re taping where I used the regular tape....I don't think it's gonna hold all that well.
