Cheap lowering?
BrockB
Indiana
Single Cab Rang
Im unfamiler with lowering a truck but are you able to do it cheaply such as cutting the front springs, or fipping a leaf spring? I know DJM have quality parts but how low can you safley go with Cheap options?
The rear is easy, get an Explorer axle and throw it in unmodified. That can be good for anywhere from 4-6 inches, depending on the condition of your springs.
Front isn't so easy. Cutting or heating springs is never advisable, but with the TIB front end going too low without modifying the beams can make is unalignable. The same is true of going too high, but it is easier to put drop brackets in to level the beams than to make them sit straight when going lower.
Ken727
St. Pete, Fl
That is an amazing thing to know. Just equal year to your truck?
Sent from my SM-N950U using Tapatalk
Junglejoe
66
Columbia Missouri
6.0
You don't "need" an explore rearend to lower the rear.. And flipping the rear shackles is a 3 inch drop . just have to buy new bolts
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
There is a "How to Tech" section at the top of every page. In it you will find a sub-section on lowering.
