Check Engine light
jlb0716
Eastern NC
2.5L
I have a 2001 ford ranger 2.5L with numerous codes showing, i believe i fixed two of them by changing the O2 sensors and replacing the fuse for them. The other codes that I am seeing are P1409 and P1451. What can I do to fix these? Would it be easier to just replace the parts causing the error? If so what parts are these? Thank you
kemo
9
USA/Minnesota
For P1451 Your canister vent solenoid may be bad. The resistance should be 48-65 ohms.
jlb0716
Eastern NC
2.5L
how long does it normally take for a code to clear the computer once it has been logged into the system and the problem as been addressed, i was told today that it is normally about 60 miles of driving for the computer to see that the issue was resolved, even though i disconnected the battery to hard reset the computer it still shows in the OBDII when i have it read (for the O2 sensors)
kemo
9
USA/Minnesota
Ford doesn't actually have a way to clear the codes without a scan tool.
