chicagodude
- Dec 2, 2007
- Reaction score
- 2
- Make / Model
- Ranger
- Automatic
Greetings,
I have a 94 Ranger 3.0. I am losing fuel pressure intermittently. I am fairly sure that it losing pressure from the fuel pump/tank. Can you tell me where the check valve is for the fuel pump? Is it possible to replace the check valve?
I put a prsesure gauge on the shrader valve and turned the key on but not start the engine. The pressure goes to 40 and holds after the pump stops. About one time every 7 or 8 tries, the pressure drops fast to zero when the pump stops. I believe it has a bad check valve.
Many thanks for any advice you can give me!
