Clutch Help.....
FordracingBII
Fort Smith Montana no sales tax and nobodys trying
1997
1997
Built 2.8L Weber carb, Comp Cam, Edelbrock Headers, ported heads, all synthetic oils
After reading thru some of the threads in this forum I know I have come to the right place for answers. Here is the situation,
I have an 85' BII 2.8 4x4. I am in the middle of swapping out the A4ld and putting in a 5 sp. :icon_welder:
I found a donor BII (85' 2.8 4x4 5 speed) to make things easy. I got the 5 speed rebuilt by a good trans/machine shop (friend) purchased a new upgraded clutch and pressure plate Kit (Zoom).
I have the external slave cylinder (new) When we pulled the 5speed from the "donor" we were careful to save all the parts and the nuts and bolts (I Think?) everything's gone smoothly until we went to put the throwout bearing into the clutch release arm.....are there some kind of clips or something that is supposed to hold the bearing in place?
I checked Haynes and chiltons for drawings but they don't show it in detail.
This is my daily driver and I cant continue the swapp until this gets resolved.
Anyone?
MAKG
19
California central coast
You have an external slave on an '85?
Then it isn't an '85.
I don't believe anything holds that release bearing in place, but the front bearing retainer snout and the clutch pressure plate.
If you don't have a snout, you need a concentric slave. It will NOT work otherwise.
Inspect the release lever CAREFULLY. It's not that unusual for them to crack, which causes release problems.
FordracingBII
1997
1997
Well it would make good sense that if your gonna ask for help....you better get your "shit" straight.... me---> :buttkick:
The donor Build date 11/83 for the model year 84'
New phrase ..."front bearing retainer snout"
would this "snout" have come with the new bearing? :icon_confused:
I would give my Left Testicle (or Right but NOT both) for a good Diagram
MAKG
19
The snout is part of the transmission.
