kturner
- Aug 21, 2015
- 0
- york, va
- Ford
97 2.3L 5 speed with about 70k miles and has been sitting a while.
Today, I drove it to the inspection station, stopping for gas on the way, which was about 3 miles. They couldnt fit any more inspections in today so I left, or tried to. I made it a few hundred feet before the clutch started acting up. I had to leave it in the parking lot next door because the clutch pedal would not move. It was stuck in the up position. It had a very little bit of give to it, maybe a quarter inch or so. I did a quick visual on the clutch pedal mechanism, master cylinder, the reservoir, the hyd line and the side of the trans. Nothing looked abnormal. Got a ride home and went back about 1.5 hours later. At this point, the clutch pedal behaved normally and I was able to drive it home with no issues.
I saw a handful of reports of this happening online, with possible solutions ranging from flush the fluid to replace the slave cylinder, throwout bearing and while you have the trans out, swap the clutch too.
Anyone seen this? What was the fix?
Keith
Keith
