- Feb 28, 2001
- 4,376
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
We have a customer at work that wants to use a 24V transmission with one of our engines that needs to run on 12V, it's on a forklift (bigger one) so not a lot of spare space for dodads... Apparently a common way is to run 3 batteries and two alternators which they would like to avoid if possible.
Google is near useless anymore with all the content out there and ads, so I'll ask where I know some people... nearly everything I've searched for ends up with questions about trolling motors on a boat which is completely different...
The transmission on 24V is most likely a light load with a few solenoids and control panel so a couple amps continuous if I had to guess. The engine on 12V will have around 8A continuous tops other than the large load at start.
What would the likelihood of success if we ran a 70A 24V alternator with a 27V regulator with two batteries in series with the engine on a center tap? Going to a 24V starter would probably help battery life but I'm pretty sure this would work decently...
Thanks!
Thanks!
