- Aug 26, 2008
- 13
- 1994 Ford Bronc
- Engine Size
- 5.8v8
- My credo
- Failing is easy. Everyone can do it.
Okay...
1995 Explorer with the Mazda 5 speed. It's been giving me a headache with transmission issues and I'll be hitting the pick and pull tomorrow early morning to see what they have for parts.
Rockauto shows:
FORD EXPLORER 1993-1997
FORD RANGER 1993-1997
MAZDA B4000 1994-1997
MAZDA NAVAJO 1993-1994
We did find a lot of Rangers with that transmission, but they are all 2wd. I'm pretty sure we would have to swap out the output shaft and the tail house extension. Now if I'm wrong about the output shaft, please let me know asap, as they had quite a few of those.
Sense ours is a 4wd, they didn't have any Explorer's with a stick shift, I'm left with either a ranger, or the mazda's listed.
Is there any other makes/models that would work? The wife noted an F150 with the same transmission and 4wd. But that does not show up on the chart.
We've found this one has bad Syncro's...And it's got a heck of a drag on the input shaft when things get 'hot'. Cold isn't a problem. Get 'er up to full temp and hot? The issues returned with going into 1st and 2nd...and reverse had the gear grind return. Shut the truck 'off' and you can shift easy. So likely either the slave is dragging it's heels (NO signs of leakage and we bleed it out about a dozen times. No air in the system that we've found)
Just planning ahead if I need parts, or if the input shaft's been partly roached by the pilot bearing.... I'd rather have one on hand that can be either hot-swapped in, or if parts are needed (shift housing/forks/etc...) They will be on hand.
S-
Rockauto shows:
S-
