Compatibility Question
matt32
Wisconsin
hi guys, i just wanted to first say that i have done a lot of research and looking around in the tech library.
but i have a question regarding whether or not a 5.0L from a 89 Bronco w/ a 5 Speed manual transmission will work in a V8 swap into a 93 4x4 Ranger 4.0 5 speed, like all the other 5.0's done from mustangs and F150's.
i just wanted to know because i found a good deal on the motor/tranny out of that Bronco, but want to make sure first. :icon_thumby:
thanks,
matt
projectnitemare
8
Osceola Mills, Pa
396W
The Bronco drivetrain will be the same as the F150. The engine and trans are no problem to fit, that Bronco t-case will be pretty large, you may want to consider looking for an older NP205 or 208 to avoid any frame cutting
Matt
matt32
Wisconsin
Thanks matt, i am not going to run the Bronco T-case, i am buying an adapter to use my stock t-case in the stock location.
Mutant Pony
9
Hersey, Mi
2300
You do know that with the stock motor you will be adding a whole lot of weight and not much else? Your power/weight ratio will probably be lower. The exhaust will sound really good though.
projectnitemare
8
Osceola Mills, Pa
396W
That will work fine but you aren't guranteed the stock driveshafts will still fit. For the price you pay for that adapter you can get a fullsize t-case, and have a set of driveshafts made; making a stronger setup. Either way will work, but going the with the fullsize stuff you can use a larger u-joint.
Matt
matt32
Wisconsin
ya that is true, but money isnt a big issue for me for this swap, so i think i am going to do the adapter. But I got a buddy that knows a place that modifies drive shafts, so i will have to check into that, maybe get a price quote, then go from there....:rolleyes:
thanks for the concern
