- Feb 16, 2012
- 0
- whidbey island wa.
- Ford
- Engine Size
- 2.9
So I have a 86/88 ford ranger that I was thinking about wiring some accessories up but I may have a good idea. I'm looking for opinions and possibilities of it working as well as a couple of questions answered.
So I have replaced all the wires in my truck. The donor I got them from had dual tanks and mine doesn't. So the trim has the slot for the dual tanks but the space looks empty without the switch. I cut the old connector off the old wiring harness to possibly wire some accessories. It looks like the connector has 5 power wires 2 are when the switch is switched to the left and 2 are switched to right. And one being main power to entire switch. And finally one ground. The power wires are red, brown/white. The red wire goes to tank selector switch and the brown/white one goes to tank selector valve. There are 2 each I those color wires for which side the switch is switched to. The main power is pink/ black. And ground is black. With the way I am looking at it is I have 4 accessories I could run but they wouldn't run all at the same time. 2 when the switched is turned to left and two to right.
So my question is if I put the switch in the middle, would power to all accessories be cut off or would two of them still be on? And if no one can answer these questions I guess I'm going to find out. Just didn't want to waste time if anyone had tried this already.
One more thing. No I wouldn't have it connected to the main harness. I would wire everything like it says to in the info technical write up under wiring accessories properly just the selector switch would be my switch.
