coolant murky
94STXRanger
Kansas City
4.0, 302
So i opened the container for the rad coolant and its all dark and murky. What the heck does this mean?
Thanks
MAKG
19
California central coast
The overflow is full of old gunk.
Open the rad cap (cold!) and see if it looks the same. If it's oil-fouled, that's a hint of a somewhat rare head gasket failure. If it's rusty, drain and refill. If it's bright and green, clean out your overflow container.
94redranger
check your oil to see what colour it is. If it is like chocolate milk that may point you head or intake failure
94 splash
sterling hgts. michigan
1994 &1990
yea if you're oil is the same its prolly a bad head gasket . if its fine u probly just have a bad intake manifold gasket...
94STXRanger
Kansas City
4.0, 302
no the oil looks good
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
What does the under side of the oil fill cap look like? If it's a milky color its either short drives building up condensation or a head gasket. Also look at the intake, check the bolts and make sure they are tight.
94STXRanger
Kansas City
4.0, 302
under the cap isnt murky.
