so hear the engine is sitting pretty in here
this is what i did to modify the fuel setup.
when i was planning on keeping the efi system, i installed a fuel cell and a bocsh 044 fuel pump setup in the bed, along with a -10AN send line and a -10AN return line, straight into and out of the stock HO fuel rails.
i used PTFE line with a stainless braided cover. as apposed to rub line, ptfe is supposed to last forever without needed to be replaced.
anyway, i cut the send and return lines back and mounted an Edelbrock fuel regulator on the fender. i then ran a 3rd line from the regulator to the to the carb. set the regulator to 5psi, and good to go. also installed a fuel pressure gauge sender.
the red box underneath is the Rev limiter by Performance Distributors (same guys i had setup the HEI distributor). its a pill style soft rev limiter, so i can set it up for 4500 rpm while i break the engine in, and then give it the full 6,000 rpm redline after 500 miles.
next on went some headers. this drivers side one was pretty miserable. especially with header wrap on it.
i ended up buying a tap and die set and chased every bolt hole on the aluminum heads and ran every header bolt through the die just to make sure they were all perfectly threaded and would go in smooth. this made a HUGE difference and helped a ton.
i used Stage 8 Locking header bolts, so i dont have any fear of them loosening up
the header on the other side wasn't much better.
got the carb on and hooked up, found top dead center and got the distributor in, wedged the triple core mustang radiator back in there, got hoses hooked up, and measured for the new serpentine belt and got that in there. fit mint. these March Performance adjustable alternator brackets rule.
then we installed the plugs, wires, and the new throttle cable from Lokar. the bracket setup from Lokar is sooooo clean for these edelbrock carbs i had to do it. im used to some haggard frankenstein thing that flexes like i have on my 4x4 van, but this is perfect.
oh, also forgot to put the dip stick tube in so had to take that driver's side header back off.
Don't Forget Your Dip Stick Tube!
now at some point i'll crawl under and take a few pictures of the tranny cross member i have going, and the custom exhaust i did, but for the mean time,
this is what the Driver's side header looks like, before i sanded it, painted it, and header wraped it.
some serious FrankenHeader stuff going on there right?
its strange, its ugly, but it fits, so im not complaining.
this is what i got for mufflers
flowmaster Outlaws
and i think i had said in the original post that we were going for a 70s mad max inspired street rod type thing, so this is what we did for tail pipes/tips/side pipes
and so now this is what we have sticking out each side of the truck
now, wouldnt you know, those flowmaster outlaws, with about 4 feet total exhaust pipe, and that engine, were Ridiculously loud. like.... ear muffs required loud.
like, i make the people at the grocery store parking lot think they are in a nascar pit crew loud.
but the exhaust job i did i thought was so nice looking, solid welds, almost no bends, smooth transitions, ii really didnt want to hack it up and try to put on bigger mufflers, so i did some hunting and found this company called Car Chemistry that makes ezhaust components for race cars, classic muscle cars, cars running real zoomies, cars running lake pipes, ect ect. these are baffles that going into the header collector, and bolt in to the 4 bolt header flange and collector flange. they were easy to install, can be easily removed, and cut the db of the truck a good amount.
these are their 2 disk option, they make a 3 disc and some additonal inserts if i wanted it quieter.
anyway,
got the truck running, first try
took a few minutes to tune, and good to go.
although we had to do some adjustments on the hydraulic clutch setup.
new clutch was MUCH heavier than the old one and needed some serious throw to disengage fully.
that was fun.
BUT
we got a STicker!
STREET LEGAL!
