Countersink bits for metal
MikeG
752
central Texas
B4000
2"
235/75r15
Tap Magic for Aluminum. Expensive, but the stuff really works.......
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,871
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Depending on the application, chatter marks could be a cause for leaks as well since the screw can’t seat flush in the counter sink.
ericbphoto
Overlander in development
16,784
Wellford, SC
3.0L
6"
Use thinner cutting oil for aluminum.
What does speed have to do with then?
Speed has everything to do with how any cutter works. The speed the cutter rotates and the speed that you feed it into the work material. You can calculate the best speeds. It's in any machinists handbook and online. Generally, larger cutters = slower speeds. Once you experience a good quality cutter at the proper speeds with the proper lubricant, you WILL be convinced.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I don't use oil with aluminum. I use coolant.
sgtsandman
Ham Radio Operator
12,871
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Coolant still has a lubricant in it before anyone asks. So, Dirman’s comment is valid.
cbxer55
767
Midwest City, Oklahoma
Precisely. At work we simply call it Feeds and Speeds. Aluminum, faster with less pressure. Titanium, very slow with high pressure. And with countersink bits, I have less chatter problem if I run them slower than I would a drill bit.
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Update: I bought a 3/4" carbide 6 flute, used medium/slow speed on drill press and tapmagic. The workpiece was secured but not clamped as it was big and heavy (6' length of 3"x5" angle iron 3/16" thick). It turned out beautiful. Thanks everyone for tips, tricks and recommendations.
