the shafts are different altogether from a d35 hybrid to a true 28.
fitting the fat bastards through the normal d28 splindle holes in the knuckle and spindle isnt so easy, its something i tried for clearance reasons in the distant past and a not worth it.
all you do is cause it to fail internally way, way, too often when you beef it externally. the 23 splines are ridiculously weak....fishing the twisted off little bastards out of there get annoying to say the least.
when these were real easy to get in the junkyards welding the shafts up at the ears was a real easy way to get by and worked great for u joint failures. weld up the diff and 6 or 7 sets of shafts could get ya by on mid level trails for a few runs with some 33 or 35 tires.
