DR83, I can't see too clearly, but do the brake caliper brackets BOLT on to the knuckle? It looks like it from here. IF they do, then the axle is DEF. from an XJ, and a pre 91 at that. The axle is a NON disconnect. That would mean that it came from an XJ with the NP 242 case, which was fulltime capable. Good stuff. Did you get the axleshafts with it? I ask because if the there is a tonering for ABS on the stub shaft, then it has the BIG u-joints in it. Those are a 297 series, which is D44 size. If not, then you can simply grab a set of shafts from a 95 and up XJ, or even a TJ and have the big joints. I prefer to pull them from an XJ, as they are cheaper because Wrangler parts are STUPID high, and 85% of XJs' do NOT get wheeled, so the parts tend to be in better shape.
Onthe steering, make sure that the the TREs' are good, and that you get the steering stabalizer for it.you really don't want to run this front end without it. It gets "twitchy" fast.
I have some pix. of some Uparmouring that I do to these things, as I have found the weak points and I don't like having to figure ot how to fix junk out in the woods if I can avoid it. I will find those, and post them in my build up.
