damaged headliner repair or replace?
Kyler Skovbo
oregon
ford ranger
the headliner out of my 91 ranger has some water damage in one of the corners, is there a way to fix the separating layers before I put suede down on the foam or will I need a new headliner?
franklin2
1,767
Virginia
I often use duct tape to piece broken headliners together. You only need it to hold together long enough for your new material and it's glue to hold it. I bet aluminum tape would work well also. You won't see it when the fabric is on it.
55trucker
183
Oshawa, Ontario
mild
Purchase replacement headliner material, strip off all of the original material, prep the backboard & refinsh the headliner.
There are various online locations to order material from, Graham Fabrics is one.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I took mine to an upholstery shop for a headliner. Guy said $100 but then only charged me $80 because there was a slight blemish, which he pointed out. I plan to get my visors done next. Turn around was same day.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
That's cheap, figuring 2 cans of 3M spray glue ($20), headliner material ($35-40), and labor.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Yea I got lucky, it was leftover material from a boat he was doing, and I'm sure he gets the glue for wholesale nothin. So it was probably 90% profit for him.
This is where it pays to pay someone else to do it lol. I made more than that using those hours to work.
Lefty
1,854
Saint Paul, MN
Ranger Edge
I picked up a very nice headliner at the U Pull yard for $11.00. Ford wants about $450. Most are no longer made. I washed mine down with a sponge damped with rubbing alcohol to brighten it up. Here it is coming out from n old klunker. It's not hard to do.
franklin2
1,767
Virginia
All the work is pulling it out of the vehicle. I used to get mine done for $75 when I would pull it myself and that included the proper headliner material. I am sure it's more now, that was 10 years ago.
I always took the GM headliners to the shop because they use Styrofoam for the headliner shell. If you use a strong glue it shrivels the Styrofoam up and ruins it, been there, done that.
All the Fords I have done so far have been cardboard shells. That holds up to the stronger glues you can get at the hardware store, and I either go to a local fabric store, or some Walmarts have a fabric section where they sell vinyl. I found some tan colored vinyl a couple of years ago at my local Walmart and that is what I glued into my Bronco II.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
I tend to price stuff out and if it is more cost and time effective to have the "professional" do it, I'll pay the price. Gladly. Plus, 90% of the time it will be a lot nicer.
