Dana 28 Control Arm Issue
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Well. Packing wheel bearings for this evenings drive to ohio, and I notice this:
That's the control arm mount on the passenger side. The gap is much larger than it looks.
Do I just pull it in tighter with an impact? Am I missing pieces? It doesn't look like there's a bushing in the slot in the mount.
FML.
snoranger
Professional money waster
ASE Certified Tech
13,696
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Yeah... that's not right. Is the rear half of the bushing still there or did it fall apart and all you have is a washer and a nut?
alwaysFlOoReD
5,126
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Post a pick of the other side. Usually there is a heat shield that will hide the plastic and rubber pieces that we need to see.
A real skookum impact might work....I ended up using a 4' snipe on my 3/4" breaker bar.
Junk Collector
Truck of Month
4,848
Rapid City SD
That's all that should be on that side. It goes nut, washer, heat shield, rubber, plastic, the bracket itself, then bushing, washer.
Should NOT be pulled away from the bracket that far, though. Without seeing the other side it looks like it's either way too loose or pieces have fallen out.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Will do. Had to run out. Thought I heard a 3500+ rpm miss. I did. This was a NGK V-Power, heat range 10 plug. Was.
Man I am not having a good day.
