Dana 30 hub options
mkyhmltn
U.S. Military - Active
Colorado Springs, CO
Ford Bronco II
2.3
I have a Dana 30 that I am going to refresh and use for a SAS. My question is has anyone ever looked into seeing if the locking hubs off a Ranger/B2 will work on this. It is a HP unit from a 99 XJ. Would like to be able to unlock the front end as it is a daily driver, but not willing to spend a grand on an aftermarket kit for a D30.
martin
26
St Bruno, Quebec
1991
The unit bearing design of the d30 makes the installation of any kind of locking hub impossible without changing the design of the complete hub assembly. Warn used to make a kit but it was expensive.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Hmm there is a tech article about putting d44 knuckles on a D35 ttb. Maybe you can do the same to a D30?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
You can take hubs off an early bronco dana 30 and put them on the xj 30 you have...
SVT
mkyhmltn
Ford Bronco II
2.3
SVT
If I did that would I be able to use the smaller 5 on 4.5 bolt pattern or would I end up having to use the 5 on 5.5?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
You'd have to jump up to the larger pattern...
SVT
mkyhmltn
Ford Bronco II
2.3
Yeah, thats what I was trying to avoid. Guess I will have to leave it as is.
brentmc
Will the knuckle assembly from a dana 35 fit on the dana 30?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Not bolt on, serious mods are needed, and not worth it...
SVT
