Dana 35 grinding in 4x
AlvinsRanger90
5
Olympia, Wa
Hey all! Wondering if bad spindle bearing would possibly be the cause of the horrible grinding when I am in 4wd?
ProjectMiniBeast
Firefighter
EMT / Paramedic
20
United States Of America
2"
31x10.5r15
The best way to check is to jack the wheel up and see if it has play in it from the hub bearings. If so, replace them and see. If that doesnt fix it you could potentially have some differential damage? Not likely but it has to be coming from somewhere.
Sent from my SM-J337V using Tapatalk
AlvinsRanger90
5
Olympia, Wa
Hi Mini Beast
Sorry so long getting back, just now seeing I had a couple messages.
By hub bearings you are refering to the wheel bearings correct?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,500
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I think that is what he is referring to.
I would start tracking the noise down by pulling things apart and inspecting as you go. Hubs and wheel bearings first. Can't say I've ever heard a spindle bearing produce a horrible grind noise.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The axle needle bearing at the rear of the spindle can causes noises only heard while in 4x4 (and is a bearing that is often neglected during servicing). Assuming the front differential oil has already been checked and verified good, this is where I'd suggest looking.
Noise from a wheel bearing would be evident regardless of whether it's in 4x4 or not.
