Dana 35 Sway bar disconnect
Mechrick
68
Las Vegas
Bronco II
I made this up over the weekend and thought I'd share. The over the axle exhaust for the V8 interfered with the rear sway bar so I removed it. From prior experience, this causes the body to pitch violently left and right when off road because the body follows the front axle. I wanted a front bar for the on road stuff, so I machined and welded up a disconnect for the driver's side.
The pin and hairpin clip came from Tractor Supply. It's 1/2" and had to be machined down to approximately .480" to fit the metal sleeve of the link. The holes in the axle bracket were significantly larger than 1/2", requiring bushings to be welded to the bracket. They must fit snug or the pin will make noise.
53509
53510
53511
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,931
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
That might work well for my rear sway bar. The SLA front suspension is set up differently. I need still need to mull over the best solution for it. Thanks for the tip.
Uncle Gump
Token Old Guy
13,643
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
SLA sway bar quick disconnect...
53543
Uncle Gump
Token Old Guy
13,643
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
SLA sway bar quick disconnect "add on kit" for rust belt Rangers...
53544
Mechrick
68
Las Vegas
Bronco II
-At the foot of the trail: "Ra-ta-ta-ta-whuuurrrp!"
"What's that noise?"
"That's Uncle Gump disconnecting his sway bar."
"What was that?"
"That's Rick dropping and losing his hairpin clip in the snow." :D
scotts90ranger
4,569
Dayton Oregon
2.3 Turbo
I like the idea of disconnects, but when I did the D35 swap I just ditched the sway bar, was going to put it back in but I don't mind the body roll, apparently my front springs aren't all that soft...
sgtsandman
Ham Radio Operator
12,931
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
