Dana 35 TTB seal identification...
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Guys I'm replacing the ball joints on my Dana 35 TTB. When I removed the spindles and pulled the shafts out there are seals on the shafts I'm trying to identify. Mine are torn and dry rotted.
On the Dana 35 parts diagram in the tech library I'm looking at #69, part number 40930. Crosses to a different number but I'm having a hard time believing it lists for 22$??? Am I looking at the right part?
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Found it. Outer axle dust seal. Found a number on the old one and crossed it.
1984RESTOMOD
62
midwest
ford ranger
302
2" BODY LIFT
33"
can you reference the #??
alwaysFlOoReD
5,163
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Rummy hasn't been on since Sept 2022. Not that long so he may be back.
1984RESTOMOD
62
midwest
ford ranger
302
2" BODY LIFT
33"
Believe I may have a part#. Spicer 50492 outer axle dust seal from dennys driveshaft. com Will check back with fitment
Junk Collector
Truck of Month
4,869
Rapid City SD
I believe you can get the whole kit from RockAuto, BCA NBSBK4 is the part number, that is for a spindle bearing kit. There are two seals you can get individually too, TIMKEN 722109 (inner) and TIMKEN 722108 (outer.)
Used to be able to get a kit from Dana with all that too, can't find it at the moment.
1984RESTOMOD
62
midwest
ford ranger
302
2" BODY LIFT
33"
I was incorrect in my spicer part #. Refer to OP; #69 in dana 35 exploded view...ford and spicer both say obsolete so left to junkyard picking
Junk Collector
Truck of Month
4,869
Rapid City SD
Ooooooooooooooooooooh THAT part... sorry, I was thinking the rubber dust seal that rides against the back of the spindle.
You have got me thinking. What is the purpose of that seal anyway? To keep grease from migrating from the slip yoke and onto the U-joint, or what? I actually do not recall ever seeing that but maybe I'm not looking hard enough. Does it go inside the female end of the slip yoke?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I've not had that particular seal on mine since 2004, and the whole time it's been fine (last time I had things apart there was maybe 5 years ago). That seal is actually inside of the axle slip-yoke boot (pt# 71, 40929) so yeah that area is already protected from dirt, water, & mud. I wouldn't worry about it missing.
