Dana 60 30 to 35 spline
FordRanger1991
So I recently purchased an HP dana 44 and a FF dana 60 that came from a 79 250.
I am going to be shorting both the axles to fit under my ranger.
I have the dana 44 shorting process down no problem as I have done one with my bro.
For the Dana 60 I will have to purchase new axle shafts anyways because I am shorting the axle. I also have to buy a new carrier for 4.56 and up (because I am re-gearing to 5:38) so knowing this I might as well upgrade to 35 spline shafts and ditch the 30 splines
With the new carrier I will be buying new Spiders to accept the 35 spline
The only other thing I can think of would be to bore out the Spindles to 1.56 right to accept the bigger shafts. (I think my spindles are actually already wide enough for them though but I will need to measure for sure)
So If your still following me... Anything major that I missed?
I appreciate the time!
1badexplorer
Firefighter
4
Sutersville Pa
3.0, 501, 7.3psd, 351c, 351w
No you got it. Just bore the housing if you have to and buy axles and carrier.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Front 60's are 35 spline, so you might be able to pick up a used carrier from one of the Chevy cucv guys for cheap. You can also pick up a used front 60 locker from someone...
SVT
FordRanger1991
Thanks for the good info guys!
I never thought of getting a front dana 60 carrier lol
Where you talking about boring in the housing?
but ya I will be getting a carrier, new spiders, and axle shafts
Thanks
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
He's talking about the spindles on the end of the tubes. 60hd and the newer 60U danas are already large enough and don't need to be drilled/enlarged. It takes a lot of time and a couple of drills to enlarge the spindles, so I recommend taking them to a machine shop. Fyi, the 60U axles have 32 spline shafts stock. I have two of those axles, and will be upgrading to 35 spline shortly....
SVT
FordRanger1991
SVT
OK ya the spindles. I was thinking he meant something else when he said housing. But so ya I will take them too a machine shop if need be.
Thanks!
cdawall
5
Ellsworth AFB
4.0L V6
I would dump the old style d60 and get a d60u. Boring spindles out sucks and clearance wise those o es suck.
FordRanger1991
How much more clearance would you get with a d60u?
cdawall
5
Ellsworth AFB
4.0L V6
quite a bit ill grab a tape measure tomorrow and compare it with the front d60 and my superduty's front d60. It was an 1-1.5" if memory serves right. The d70u's have more clearance than an old school d60 for perspective.
donfordguy
ive been thinking about 3/4 ton axles on my ranger I got a 2wd wonder if I could make the 3/4 front parts work just think it be cool to have a 3/4 ranger
