Dash Light Wire
1984ranger28
5
Davison, Michigan
2.8l
What is the color of the wire coming out of the dimmer switch that goes to the cluster? I have a first gen Ranger. Thanks, Lucas.
3,614
Light blue with a red tracer.
If you want an example of it, the easiest one to access is behind the ash tray. Take the tray out and look in the cavity, there should be a bulb in there hooked to the dash lighting. You should be able to pull the bulb out far enough to handle it and work on the wiring if you need to.
1984ranger28
5
Davison, Michigan
2.8l
Thanks a lot! It was for tachometer lighting, works great.
