Depower Rack
GTOKID64
Chicago area
Hi - I have a 99 Ranger and am planning on building a dedicated drag truck for 1/8 and 1/4 mi bracket racing. I need some input on depowering the rack and pinion outside of looping the lines - unless that is the only way. I depowered a Mazda Miata rack last year by dissassembling and cutting out the internal piston.
Any input would be great - Thanks.
19Walt93
4,500
Canaan,NH
351
3"
235/55R16
I think looping the hoses is your only choice. Obviously the rack will wear out quickly without fluid circulating through it but it shouldn't be a problem for a drag truck.
ericbphoto
Overlander in development
16,742
Wellford, SC
6"
Wait. Aren't drag strips straight? Get rid of all the weight of the steering system. Weld the wheels straight!
GTOKID64
Chicago area
Thanks, I appreciate the input - I depowered a 91 Mazda Miata rack last year - there is a procedure on-line - basically you dissassemble the rack and remove the piston that separates the driver/passenger side on the shaft - then reassemble. Pretty common in the Miata world - nothing in the Ranger world.
19Walt93
4,500
Canaan,NH
351
3"
235/55R16
Take it apart and look it over, the same procedure may work.
racsan
4,503
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
not sure how similar it would be, but what about a manual pinto rack?
