Diagnosis help, need to replace AC compressor?
sheliable
12
Cincinnati
Ford Ranger XLT
I need to replace my ac compressor right?
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Maybe just the clutch.
Does the compressor clutch ever engage?
JoshT
1,761
Macon/Fort Valley, GA
Impossible to diagnose from that video clip. There are a number of things in the system that could cause that clutch to not engage. As much as I hate to send anyone to the professionals, I'd recommend taking it to someone with more knowledge to look at in person. With us guessing from that clip, you could end up replacing the entire system when you have a broken wire or bad relay/fuse.
Junk Collector
Truck of Month
4,808
Rapid City SD
May just need a clutch, sounds like a bad bearing and it looks like the clutch plate is wobbling a bit? Pretty hard to tell from the video, it is pretty short and we need more details on what is going on to help you troubleshoot it.
