Did my MPG go down?
CT
1987
2.3 & 7.5 460
I put on some 235 tires on my 93 and now I think the speedo is about 2 mph off. Is there a way to find out how many mpg I am getting without new speedo gears? Thanks
triumphrider-1
14
Port Huron, MI
Ford F150
3.7L
Whats the stock tire size?
MountainMike
84
Canada
245 CID
2"
31"
The fun begins where the pavement ends
And what is the aspect ratio/rim size of the 235's?
CT
1987
2.3 & 7.5 460
I do not know the stock size. I will lookit up on Mon. when i get it back.
94 lngbd
7
Lakewood,Wa
2.3l
a 93 2wd should be 225/70r-14
MrE_Powers
12
st. chuck county, mo.
3.0,4.6,2.8
gps will help get you accurate mpg
LearjetMinako
12
Moore, OK
2.3L 140ci
There is a 9~10% difference in tire size. So when you do MPG calc, add 9~10% of the figure number to the total. Ex. If you got MPG= 200, 200 x 1.10 = 220 MPG. This should also correct the Speedo as well. Instead of 65mph, 65mph (indicated) x 1.10 = 71.5 (corrected indicated). A GPS should confrim the results.
