Did you lift your 1998-2011 Ford Ranger 4x4?
  • Bought the Superlift kit
    Votes: 10 12.8%
  • Bought the Superlift kit & installed a body lift
    Votes: 5 6.4%
  • Bought torsion keys and cranked the torsion bars
    Votes: 13 16.7%
  • Bought torsion keys, cranked the torsion bars, and installed a body lift
    Votes: 5 6.4%
  • Cranked the torsion bars with the factory keys
    Votes: 27 34.6%
  • Cranked the torsion bars & installed a body lift
    Votes: 12 15.4%
  • Only installed a body lift
    Votes: 6 7.7%
  • Total voters
    78
clarkbre
26
Snohomish, WA
Since my Jan. 2nd post, the project has taken a slightly different route on wheels and tires. Sometimes I think things just happen for a reason. With the planned black steel "D" window wheels, I was a bit concerned about adding 9 lbs of rotational mass on each corner, the truck driving worse than stock and I didn't really want the "blacked out" look. They sold in a day and I was satisfied saving for new 31's and using the stock 15x7 wheels.
Cruising Facebook Marketplace, I found a great deal on a slightly used set of wheels and tires in the exact size needed:
Wheels: American Racing AR23 machined w/ clear coat fisnish 15x8, -19mm offset, 3.75" backspacing
Tires: Pro Comp Xtreme MT 2 31x10.50R15
They fit great and still have plenty of room for no rubbing. I love the new look of the Ranger!
MaicoDoug
Ham Radio Operator
55
Texas
Ranger FX4 LVL2
2 inches in the back, not enough in the front
32x11.5x15
Yep 31's are about all we can fit up in there.
How did you level the front end?
Those machined aluminum wheels look great. Ford always had some very nice looking factory options wheels, and dang if those don't look exactly like it. Small touches make the suddle difference....and make a big difference to us types. Hope you can get her in the mud soon and then toss a picture our way.
I totally rebuilt my front end just before raising the front up 1.75" with a coil over mod. It was easy to R&R all the front suspension, no special tools required. I sold off the T bars to someone here for the cost of shipping.
-Doug
clarkbre
26
Snohomish, WA
How did you level the front end?.....
......-Doug
Looking at all the clearances with the wider wheels, there is definitely room for 32x11.5's without rubbing issue. I'm still going to keep with the 31's for general driving.
The front on mine is leveled just by adjusting the stock torsion bolts/keys. They took 3 full turns on each side to bring the front up about 1.5". It isn't maxed out and there is still upward adjustment if needed/wanted. With corrected tire pressure on all 4 corners, the fender arches all sit perfectly at 36" off the ground. Couldn't get more level than that! To compensate for the raised front end, Rancho RS5000X extended length shocks were installed. Part #RS55374.
With the current setup, the truck rides great! Not being maxed out and with the longer shocks, there is still downward travel available in the front suspension.
CamTheHedgehog
ASE Certified Tech
388
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
Maybe I should toss my two cents of experience in here.
I just cranked my torsion bars, as I have a pre-2008 ranger. Why? A couple reasons. A- I wanted the truck to not be as canted forward, B- I am lazy and don’t have the time to install a proper lift, C- I am cheap and don’t want to spend the money on a proper lift, and D- I wanted to fit bigger tires.
The keys aren’t quite maxed out, but close. I can now comfortably fit 265/75R16 tires, which are basically 32”.
Someday, if I have the time and money, I’ll buy the superlift or rough country kit. Someday.
