difference in axles
rawrrediffer86
Illinois
What's the difference in the rear axles of a 8.8 3.73 97 ranger & 8.8 3.73 98 ranger? Need to know I have 99 at the junkyard I work at & was just wondering cause I blew out my gears in mine & just wanna swap trying to figure out the difference cause interchange says 93-97 only. Is it the perches? Or something else.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
I don't know of any differences unless it's in the brakes.
cvar
19
Mazda
4.0L V6
In the TRS tech library: (click-here), it says:
"In 1998 the Ford Ranger went to a Dana 35 IFS front axle. The Dana 35 IFS switched from a reverse rotation gear to standard rotation gear. The gears in a 1997 and older Ranger/Explorer will not work in the 1998 and newer Rangers."
Wouldn't the direction of rotation affect rear axle too?
PanamaExpat
13
Panama City, Rep. of Panama
Mazda
4 liter
No it would not. The rear axle has always been standard rotation. Reverse rotation was special to the TTB front end.
AFAIK The 8.8 should be the same in those years... Get out the camera and the tape measure to be sure though.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
rears should be the same. different sized drum would be the only thing i could think of.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
The brakes wouldn't matter to me anyways converted to disc brakes two weeks ago.
I'd say you're good then. Maybe your system has it confused with the front differential or some crap like that.
3,615
It will work, just use it.
