Dirty rotten stinking piece of C4 garbage!!!!!
Looks like you're not splining the direct clutch to the forward clutch drum properly. When you push on the top of the that stack , does it feel springy?
No, it feels solid to me, and it drops to the same spot even with the clutches removed. That's why I am so stumped.
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
Hard to say without actually being there hands on. Can you take a few pictures with the gear train apart?
I will work on it in a few weeks. It is still wet and cold out, and I'm just about out of all forms of heat, trying not to buy more this year.
