Distributor issues
rsm5773
1985 Bronco ii
2.8
I have a 85 Bronco II that had a bad 2.8 engine that I pulled out and replaced with a 85 ford ranger 2.8. In this process I'm doing the duraspark conversion and bought the distributor from Autozone per the duraspark conversion part # in the technical library.
I'm having a hell of a time getting the new distributor in. The old one went in with out many troubles. I have also replaced the oil pump and shaft with the melling one. The teeth one the old distributor match the new one if i mesh them together. Maybe I just got lucky putting in the old one?
Has any else had a similar problems? Any thoughts :icon_confused:
18,002
SW Iowa
I had to sand the base of mine to get it to go in, just a tad too big.
rsm5773
1985 Bronco ii
2.8
Base of the shaft that goes into the cam/oil pump or the base of the distributor
Thanks
skippy
38
Georgia,USSA
2.8l durasparked rice killer
Thanks
Where the Dizzy goes in the block,I had to do it too.
Lifted2x
Medford, OR
I have done 4 durasparks with cardone dizzys, and i have had trouble with all of them. I have had to sand the end of the shaft that runs the oil pump and on others the aluminum casting that sits inside the block.
