Do I have the right bulbs for dash?
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
I was watching vid on how to change out dash bulbs, and they say for Ranger 93-03 the bulbs have quarter-turn to lock, they are mounted in a plastic base. But the ones I have are just bulbs with no mounting. Do I have the right ones for my truck? I don't want to get the whole thing apart then end up with wrong part, that would suck. I have Sylvania Silverstar #194, that's what the parts store said I need. They don't look like the ones in the vid (no base on mine). Here's the vid I watched:
the rest of it apart from bulbs themselves looks just like mine, I've had most of it apart before, just not the dash cluster out, yet.
8,374
Yes, the bulb socket is removed by the 1/4 turn, then you pull out the old bulb and put in the new one, then re-install
Stock bulbs are "incandescent" type, so have no dedicated + and - side
LED replacement do, so they have to be installed the correct way, so power up the dash before putting back in to make sure all 6 are working, you should do that with either type of bulb, lol
James Morse
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
Oh, ok. Thanks RonD. Sounds like I'm good to go.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
BackLamps
LitBulbs T10mmWedg*23mmLong 12volt 3\4watt Sylvania# 161\194
Sockets T10mmWedg*13mmCircuitHoleMt FordMotorCraft# c80z-13711-b
* Do Not Use Higher Wattage Bulbs, They Will Melt Plastic Sockets
* 6each In DashLeft InstrumentCluster
* 2each In DashCenter AirConSelectors
DutyLamps
LitBulbs T5mmWedg*18mmLong 12volt 9\13watt Sylvania# 906\912
Sockets T5mmWedg*7mmCircuitHoleMt FordMotorCraft# f57z-13b765-ba
* 16each In DashLeft InstrumentCluster
* 2each In DashCenter 4WD+RearWindowSelectors, Sockets Require Mod\Add
Click here for more info.
