Dome light / Door ajar light issue
mtm006
I am having problems with the dome light and the door ajar light on the intrument panel staying on when both of the doors are closed. This only seems to happen when the passenger door is opened and then closed. Any suggestions?
ghost_rader
Hubert, NC
4.0l
what year, i know that newer rangers have the door ajar switches in the latch assy. and they fail. this might be your issue
mtm006
It's a 2003, the light will stay on for a little bit and after awhile it turns off. It seems to malfunction if someone slams the door.
Wicked_Sludge
43
Westport, WA
3-point-GO
the switch is inside the door latch. open the door and hose the latch down with your favorite spray lube (trying to work it in behind and under the switch). this will free it up. sometimes lasts a few months...sometimes pretty much forever.
Muddycowboy
GOT MUD?
Randolph, OH
mtm006
I tried to lube the latch, and I thought it was fixed. Then it did it again, I noticed that when it does turn off the light there is a clicking sound.
Wicked_Sludge
43
Westport, WA
3-point-GO
did you lube both door latches, just in case? if you did and they are still sticking, its time to replace the switches (see junkies post).
the clicking is probably the relay clicking off.
mtm006
Well I only did one, but it seems like this won't just be a quick fix from what I'm hearing. It doesn't even really bother me, it's the gf that keeps complaining about it. Maybe I'll just make her ride in the bed. haha
Wicked_Sludge
43
Westport, WA
3-point-GO
spray both sides. spraying the latches fixes the problem 99% of the time....you just cant be scared to really go nuts with the spray lube.
