Door switch for dome light. Where is it?
RangerVet
34
Kingman, AZ
FordRanger Edge
From here on down it's uphill all the way!
2005 Ranger 2 door. Sometimes the dome light comes on when I open the driver side door and sometimes it doesn't. So today I grab my WD 40 so I can lube the plunger switch on the door jamb. I cannot find one. Where or what causes the interior light to come on when you open the door?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
It's on the door itself not on the door jamb. Its attached to the latch inside the door.
ericbphoto
Overlander in development
16,627
Wellford, SC
6"
There's another great idea from Ford's "Department of Making things more Difficult for mechanics".
(I've got to work on that name so it has a cool acronym - maybe Department Of Dumb - DOD)
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I think the reason was because theres no way to use an old fashion door jamb switch on the suicide door cabs, and there was no point using a seperate style switch on the regular cabs. But yea... it's a pain to replace.
That may be a valid theory for why the Rangers have that style. Now explain the entire rest of Ford's lineup.
snoranger
Professional money waster
ASE Certified Tech
13,675
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
It's 1 less part to install on the assembly line. Someone had to install the pin switch and someone else installed the latch...
now one person does both jobs at the same time.
One less person mean, 1 less salary, 1 less family medical insurance, 1 less pension... look at all the money that just saved Ford.
19Walt93
4,482
Canaan,NH
351
3"
235/55R16
We used to see problems with door hinges squeaking and switched sticking on vehicles maintained by Jiffy lube. Our techs would lube the door hinges and latches during services. Spray the door latches and open and shut the door several times and you'll probably be all set. I like Cyclo Breakaway best.
RangerVet
34
Kingman, AZ
FordRanger Edge
Thanks! A spraying I will go!
sgtsandman
Aircraft Fuel Tank Diver
12,687
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Yeah, like mentioned above, it's part of the latch. So, you'll need to pull the door card and plastic vapor seal to get at it. I hope you can get it to work with a spray. Access isn't that great from what I remember when I replaced the passenger door on my 1998.
