dpfe failure
craig
lawrenceville ga.
ranger
this 94 2.3l has gone through 3 dpfe. it has #4 in and seems to be ok...now. it gave off 337 code koeo, and memory 327, 337. replaced dpfe and light went out without me clearing codes. Does anyone have any clues? I am thinking of cleaning the pipe that connects on the egr valve, since I have read that the dpfe is sensitive to any carbon/dirt etc., that may be in there. I understand there is a orifice in that pipe between the 2 pipes that connect to the hoses on the dpfe. while there, anyone know how to prevent the hoses from heat welding themselves to the small pipes from which it reads exaust pressure? one hose is from auto zone, one from dealer. they are the special hoses for this application. Also, egr valve gasket very well secured to engine side of assembly, how is it advised to remove it? not much room so close to firewall, maybe someone had used an adhesive there, I don't know. BTW, dpfe is mounted on the firewall. thanks in advance
tomw
46
lima bean
vertical and above ground
Some say aftermarket DPFE sensors do not last too long. You might try a boneyard model, but don't pay too much unless they guarantee it for at least 90 days. PigiinaPoke if they offer no warranty on their electricals.
The hoses are indeed special, and costly. I would go again with a dealer part even at more expense as I know nothing about the after market hoses. If you have had good luck with a particular brand, that might be nice to share.
tom
RB7 Ranger
5
Tn
3.0 litre
I agree with Tom, use a Motor Craft DPFE,
three checks on an EGR system
1, are the passages ,clear? engine should drop at least 100 rpm at idle with valve opened, really should just about kill the engine if passages are good and clear
2, is the diaphram good? will the egr valve hold vacuum? if it bleeds off or does not hold at all its bad, very rare on these fords
3, is the egr valve getting the right amount of vacuum at the right time, Vacuum supply, egr-evr, drive down the road with gauge under wiper arm or similar with green line attatched to guage, under light to med. load you should see 5 to 8 inches of vacuum
craig
lawrenceville ga.
ranger
dpfe etc.
what of the cleaning out the pipe? HOW TO REMOVE THE STUCK ON GASKET? thanks everyone.
tomw
46
lima bean
I have seen a ball peen hammer used on stuck on gaskets. Using the rounded side, tapping lightly all over the gasket, and it seemed to come loose readily afterward.
I tried it on a gasket with some success. Remainder removed with a putty knife or blade.
tom
craig
lawrenceville ga.
ranger
egr gasket is glued solidly on the engine side of assembly. this gives very little space to get at it, so close to firewall. prior, I had done the 3 checks to egr system, well 2 of them, I did not have access to a plain vac checker, so doing the driving test, I did not. the other components did pass however. thanks for your consideration
