drivers side coil bracket ?
1989
kalama wa
2.8
on my ranger its got a a hump on the drivers side frame side from the power steering box (outside of the frame ) how do i eliminate the monting problem of it not monting flat ill post pics
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
I/We STILL dont understand what youre trying to do...
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
When I put EB coil buckets onto mine, I cut and reshaped the back of the bucket to fit over the hump in the frame.
1989
kalama wa
2.8
im thinking about just welding some shims in to make it flat and drilling the holes threw to mount the bracket but other than that i dont know what to do to fix it
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I just told you....
yyc_tbird_sc
Firefighter
EMT / Paramedic
6
Calgary, Alberta
^^^This!!! I've got some after-market spring buckets that I'll probably notch to fit around the bump in the frame. If you start shimming things out on the frame, you'd better do the same on both side or it'll be uneven.
1989
kalama wa
2.8
i see what your saying now ok thanks for the advise im gonna go get stated on it right now
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
This is what I did. Its 3/16" plate that I used and I used my shop press to bend it to shape. Its not finished in this pic. But gives you a good idea. And I welded a 1/4" plate on the bottom to support it.
Hagan
11
Salem, OR
2.3
Are you going full width or narrowing your front axle? I would recommend NOT to space the buckets out from the frame.
1989
kalama wa
2.8
im going full width is your truck full width or shortned ?
Hagan
11
Salem, OR
2.3
Its full width. What year axle did you get? (the cast on radius arms or the weld on?) Mine is the removable weld on type and I moved my radius arm wedges in 2.5" on each side to match the width of the Ranger frame AND to move the radius arms in so they won't rub on the tires.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
That is exactly the way I made mine fit, I just used a piece of small angle and flattened it a bit to fit over the hump.
Hagan
11
Salem, OR
2.3
Glad I'm doing something right!:)
1989
kalama wa
2.8
if i saw right the wedges are cast on how do i move them in or fix that problem if there cast on ........
