bottledgt
- Aug 22, 2007
- 0
- Age
- 47
- ford
ive got a 2 piece custom driveshaft setup im trying to finish up on this ranger of mine. they wouldnt make me a one piece as it was too long to take the rpms. so they told me. so they made me this. now im trying to get all the angles right before i weld the carrier mount for sure. ive just got it tacked in right now, but i have the 1st shaft at 1.5 deg down from the transfer, and at the carrier bearing i have 8 deg angle, and at the rear i have 6 degrees angle. also the rear is offset slightly from the transfer centerline. (maybe a degree). should i come out of the transfer straight with the first shaft or should i mount the carrier bearing mount directly in line with the 2 ends? heres a pic to kinda see what i have going on. im thinking i should drop the carrier a bit, but am not sure,. according to spicer, the first shaft shouldnt be more than 1.5 degrees down from the transfer.
