2.3L ('83-'97) easiest low pressure fuel pump setup
stamina
34
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
im putting a carb setup on my 88 long block, the truck is a stock 4.0 setup/fuel pump. i know i need a lower pressure fuel pump, 5-7 psi from what ive read? what kind of pump do yall recommend and what kind of setup do i need for my 2bbl carb?
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'm pretty sure the 88 still had a lift pump in the tank and the high pressure on the frame rail. The lift pump will work with a carb.
scotts90ranger
4,412
Dayton Oregon
2.3 Turbo
Yeah, that, just pull the high pressure pump in the framerail and put something in its place and bob's your uncle...
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,502
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Your 90 Ranger with a 4.0L should have a single high pressure in tank pump.
When I swapped a V8 in my 88... I installed a Holley blue pump on the frame rail and simply pulled fuel through the in tank pump. I also installed an in line pressure regulator for control of overall line pressure at the carb.
Maybe not the best way... but it worked flawlessly forever.
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Oops... I'm on mobile and didn't see he had a 90 truck and an 88 block.
17,910
SW Iowa
Doing the same but I think I have a red Holley.
In tank pump is probably the way to go but they don't last very long and are a PITA to swap out. A frame mounted pump you can easily swap in a parking lot.
scotts90ranger
4,412
Dayton Oregon
2.3 Turbo
Yeah, I even re read that and missed the 4.0 part... there's a bunch of Walbro low pressure in tank pumps that I'd probably trust... would likely take a little rework on the down tube
