Engine assembly lube
4.0blue98
I don't feel tardy...
692
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
Never touch the inertia switch! They only work (properly) once and need to be replaced. The only reason they can be reset is so the vehicle can be driven far enough to get somewhere for repairs.
Interesting and good to know. Thanks!:oops:
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
if tripped via collision. did you get that data from first inertia?
tomw
46
toenails of foothills NW of Atlanta
lima bean
vertical and above ground
Dirtman, the style inertia/rollover switches used by FoMoCo are readily reset and do not need replacement if they are operated manually. Inside the switch are two contacts with a steel(?) ball bearing of good size sitting on top, touching both contacts. When disturbed by inertia or rollover, the ball moves off the contacts breaking the circuit. The button just moves things around to let the ball fall back into place. Nothing is damaged or changed in any way by the switch opening. Go to a boneyard and take one apart, or take yours apart and have a look.
tom
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
tom
that is why i asked if he got that info from first inertia.
because the early switches never get replaced untill they corrode.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I've just had first hand experience with the switches after they are tripped. I've had them trip just by slamming a door once "used".
In any case, theres no reason to be touching the switch for the purpose of disabling the fuel injectors...
snoranger
Professional money waster
ASE Certified Tech
13,674
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
How come Ford doesnt tell their techs that they're 1 time use?
34420
