nobbyv
- Dec 4, 2007
- 0
Hey guys, hoping someone can help: '97 Ranger 2.3L that I bought a few months ago as a Home Depot/dump-run truck.
The issue that I'm having is that before the engine has a chance to warm up, it will stall out after I rev it. So it starts fine, and will happily idle forever. But as soon as I give it some gas, it revs up but then falls down too far and stalls (I can "catch" it with the throttle, but as soon as I let off the gas it stalls). It's then very hard to restart immediately. After the engine has been warming for 5-10 minutes, all is good.
I've replaced: IAC valve (my first guess), all 8 plugs, wires, air filter, fuel filter and O2 sensors. I pulled the MAF, and it looks SQUEAKY clean (as in the previous owner must have replaced it within the last 5k or so), so I ruled that out.
Checked fuel pressure, seems OK. I got a nice 12-14" stream of fuel when I pressed on the Shraeder valve with the key in the "ON" position.
I also spent a good twenty minutes with a can of carb cleaner looking for vacuum leaks, and couldn't find any.
Anyone have any other thoughts on what to check?
