engine swap
milfchaser
which one
which one
will a 4.0 bolt in place of the 3.0 both are ohc engines both auto trans please help the 3.0 is in an 02 b 3000 :headbang::3gears:
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
yes they will bolt together. there is alot more to it than just bolt patterns.
milfchaser
which one
which one
thanks for your input
i have built a few cars in the past but since katrina i have switched modes ,i just wanted to be sure before i yanked the donor engine just to find out it was a different pattern and have an engine sitting around as opposed to it being in the donor truck out of the weather thanks for your input:icon_hornsup:
milfchaser
which one
which one
hey bud thanks i gave you kudos
alaskan155
6
washington
FORD
7.3l/4.0l
4.0 will not bolt to 3.0 tranny and vise vera, but the 4.0 with 4.0, 2.9, 2.8 tranny will bolt in
kunar
131
Toledo, Ohio
5.8l
bellhousing bolt pattern is different...can you use the trans from the donor truck?
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Ye, the bllhousing pattern is different between the 3.0 and the 4.0.
And BTW, the 3.0 is NOT an OHV engine.
The 4.0 MIGHT not be...
AllanD
