Jeide
- Aug 25, 2023
- Reaction score
- 7
- Location
- San Diego
- Make / Model
- Ford/Ranger
- Automatic
I’ve got a 2000 Ranger with. 3.0 liter engine. After I bought it, I had to replace the engine because the one it came with ave out after 245,000 miles. The new (used) engine has been working out well. After fine tuning things a bit, I am left with one trouble code that is preventing me from getting it smogged. It has a P0443 code, which is an evap purge valve circuit problem. I invented in the power train/emissions shop manual and followed the pin tests in there and came to the conclusion that I need a new PCM. That’s fine, if that’s what it needs. I also downloaded the Forescan software, so I’m prepared for the replacement but I don’t feel like I fully understand how that purge valve circuit works. The main problem that I have with it is that the manual says “
“ I’m not sure if this is something that I can do on Forescan. I did go to the section where I can read the various PIDs and pulled up the output control where I could turn on and off the purge valve. When I metered from the purge valve and ground I got the full battery voltage. Is this where the manual is saying I should see between .5 and 1 volt? If so, what does seeing full battery voltage there mean. I’m planning on replacing the computer regardless, but I would feel better about it if I understood these readings. Thank you if you are able to help.
Monitor EVAPPDC PID and voltage between EVAP canister valve signal and PWR GND in output test mode with key ON engine OFF (or in key ON engine running mode). EVAPPDC PID at 0% and voltage less than 1.0 volts (or EVAPPDC PID at 100% and voltage greater than 0.5 volts) indicates a hard fault. |
