EX auto tranny to manual swap
CKRobin
Conway, AR
So you still need some parts? I am doing the oposite swap as i drive a dump truck every day at work I want to be lazy in my personal vehicle. I have a 91 with a 4.0 5speed I am about to put a new motor in and replace the 5 speed with an auto.
tjs4x4
ID
I need a shifter boot, manual tranny wiring harness.
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
'91 and '94 trans harnesses are different.
tjs4x4
ID
That's right...sorry. Do you have a decent shifter boot?
CKRobin
Conway, AR
No my boot is torn around the bolt holes. I was hoping to work out a swap as I need alot of your parts but after noticing how far u are from me I would probably fair better to just buy a junker close to me to steal what I need from.
tjs4x4
ID
Yeah, sorry. Thanks anyway.
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
They're all the same.
tjs4x4
ID
Do I have to have the one with the metal pole sticking out of it, or can I just buy the first one that is the cheapest?
THEN, I ALSO have to get a neutral safety switch?
I have parts that I'm looking through, and need to know what a TOB and pilot bearing looks like. Are the TOB and pilot bearing on the slave cylinder along with the spring? Ive seen pics of slave cylinders that looks totally in one piece, but I need to know the individual pieces.
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
That metal rod is for the master cyl. Your master should already have one.
Most slaves come with a TOB. Most clutch kits come with the pilot bearing. The pilot bearing doesnt go in the slave, it goes in the end of the crank or the flywheel, depending on the design (4.0ls have it in the flywheel.) It supports the tip of the trans input shaft.
tjs4x4
ID
Ah ok gotcha. Ok, so I have the clutch switch on the rod on the master, what connects to that?
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Which, the clutch pedal switch? Theres a connector with a jumper under the dash. Remove the jumper and plug it in.
Or the rod? It connects the master and the pedal together.
tjs4x4
ID
Yeah the clutch pedal switch. Its got a whole buncha connectors on it. What color is the jumper under the dash?
snoranger
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Its hard to miss. Its the only connector that looks like it will fit in the clutch pedal switch, and its within a few inches the where the switch would be.
There you go again, making this harder then it is. :D
tjs4x4
ID
Ahhh hehe gotcha! Sorry, I'm a visual person ;)
