'92Custom
- Apr 3, 2011
- 2
- Alexandria, VA
- Ford
- Engine Size
- 4.0 V6
1992 Ford Ranger 4.0L OHV
For the last year or two I've been getting 17.5 MPG almost every tank (mixed city/highway). Lately I've had an intermittent check engine light that shows up after the engine is hot, and fuel economy has plummeted to around 10-12 MPG, which is bad enough to make me miss my old 460.
Yesterday I ran diagnostics key on, engine off, by jumpering the connector under the hood to get the codes to flash on the dash. I also tried to get the codes to flash with the engine running, but for some reason that wasn't working (ran the engine for 2+ minutes, shut off the engine for 10 seconds while adding jumpers, then restarted the engine - no flashing CEL).
KOEO, I got code 173 and 179, both of which relate to the O2 sensor which to my knowledge has never been replaced (~132k miles). I replaced it with a direct-fit Bosch unit from Auto Zone and went for a test drive. Apparently nothing changed because the light still came on.
Now I'm headed out to check the codes KOEO again and see if they are the same. In the meantime I have two questions if anyone can help.
1) do the codes 173 and 179 point to a different problem than the O2 sensor that I may have overlooked?
2) what am I missing to get the KOER codes?
