If i was gonna be running a 9" or something bigger in the back end i'd do the chevy leaf swap, so that way i could move the rear end back farther(hopefully) but as i'm just running the 8.8 31 spline i'm just sticking with ranger/explorer leafs. Really don't feel the urge to chop and cut and re-drill the leafs for the back. especially since the SAS will be done as fast as possible but correctly as this is my DD.
its funny how many people posted without actually reading what he was saying
the 3" explorer rear leaf springs you found will net u about 4 1/2-5 on a ranger, u will need to flip the center pin but they will bolt right in, and run the longer shackle. this combination will net u about 7-7 1/2 total, and then u can run a 1" or 2" factory style ford block to make up the difference.
I know you gotta flip the pin, but the shackles between rangers and explorers are interchangeable then? just wasn't positive on the interchangeability between ranger/exploder leafs. would maybe a ford stock block out of an f150 fit in there and still give me more lift? don't know if they are bigger or not? just gotta be careful about getting too much block in there since i really don't wanna spend the $ on getting longer ubolts. Just making sure i spend the money i spend in the right places, and would most definitely go suspension then block. i had major axle wrap problems when i was running blocks before... sucked! don't wanna go back. i already re-packed my leafs with some leaf packs from a dodge? half-ton maybe? way old, so the leaf pack i have now is 6 or 7 leafs lol... and its giving my ranger about 4" lift as it is right now so the explorer leafs wouldn't be much benefit, guess i'll just be forking out the extra 100-200 for the 6" leafs, and shackle it up, and hope for the best
Guess i could always call pohl springs up and get and these ones re-arched? i heard they can really only get re-arched about 4" lift before they are too distorted to fit again?
