Explorer swap
Rangerdan2.3
Fords and a Tri
all
I have searched and searches and I am still not sure what engine mounts to use. I have an 01 X-cab Ranger and a 97 explorer. Do I use L@L, vert mounts, stock sploder mounts or custom fabricated ones?
Any help is appreciated.
Thanks
alaskan155
6
washington
FORD
7.3l/4.0l
4x4 98+/edge 2wd(torsion bars) = explorer 95-01 v8 mounts bolt in
2wd 98+ (coil sprung) = custom
Rangerdan2.3
Fords and a Tri
all
Sorry it is an 01 xcab 2wd, so will I have to mke the mounts? If so is there a template or plans I can go off of, or is it to each his own?
Thanks Dan.
RangerPliskin
2.5 wants to be 5.0
Mounts
The coil spring motor mount issue has been discussed at great length, but I still get confused about all the different options, too. I just finished installing a 5.0 from a '99 Explorer into a '98 Ranger with coil springs...this is what I did.
I bought two motor mounts from Rockauto...about $27 each. Anchor Part #2853 (front right). Not sure, but I think they discontinued the front left because they are basically the same as the front right. The passenger side mount dropped right in, the driver side I had to drill a hole for the index pin then it fit right in.
You've read about Brian's adapter plates, which you may be able to get a drawing of but you'll probably need to get them fabricated. Apparently a very good design, but I decided to make my own. Rather than welding an offset plate, I just used a thicker piece of material on the driver's side...some may argue that this leaves the engine too high, but my oil pan is only 3/8" off of the steering rack and I didn't feel comfortable dropping it any more.
I hoisted the motor into place, took measurements and made cardboard mockup plates to verify fit. Then I cut metal. Maybe not perfect, but I think it will fly.
Rangerdan2.3
Fords and a Tri
all
Does anyone know where I can find the template for the mounts? I have heard there is a template but cannot find it.
Thanks
Dan
Mac
183
C. Wisconsin
2000
199
Brian B. came up with the motor mounts for the later coil spring suspension, he's a Ford engineer. He requests $20 to be payed to his PayPal account for reasons not for his personal gain. Shoot me a PM and I can connect you with him and the plans.
Dave
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
RangerPliskin, what are those mounts originally for? (Anchor Part #2853)
Ranger 4.0? Just curious, they're may be a later model swap in my future.
EDIT:
Did my own search, mount is 4.0 ranger, maybe others, I didn't look too hard.
