extreme camber bushings
Dusty_Ranger
4
Salmo BC Canada
i got a set of extreme camber bushings and was wondering how many inches of lift out of the stock front suspension using coil spacers and the bushings
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Not sure I fully understand your question (did you finish typing?)
If you're asking what's the maximum lift you can get without any drop brackets, it's right about 2". Although if your current springs are pretty sacked out, you may see more apparent lift before you hit maximum.
