f series 4X4 trucks
1993rangerxl
Florida
4 banger 2.3L
What are the pros and cons of the different motors and trannys used in Ford pick ups? The 4.9 I6; the 4.6,5.0 and 5.4? Auto or manuel trans. My interest goes to reliability, and high milage (300K +).
The 4.9 is hard to break, but gets crappy mileage, worse than the 5.0, and it doesn't have the power of the small block. The 5.0 is really more of a car engine, but is reliable, not many major issues I know of.
The 4.6 is also a good engine, but many guys say under powered. I think they are wrong. The 5.4 is also a good engine, but was never offered with a manual trans. Both the 4.6 an 5.4 had issues with exhaust manifolds warping and/or cracking. The 2V versions spit plugs, and the 3V versions are prone to cam phaser issues at high miles.
The 4R70 and 6R80 autos are both good trannies, as was the M5OD-R2. If you go manual I would stay away from the 97-04 Heritage body, the ones with torsion bar suspension. Getting the trans out without a lift is... difficult.
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
the 4.6 in my dads '97 f-150 has been about the only thing we have been able to rely on, due to neglect and age the rest of the truck has been falling apart around it. It will pull and haul fine, it just takes a little while to get up to speed. I think just a good set of headers on them and you're set. If I had to choose between 2 engines out of your list, I would choose either the 5.0 or the 4.6. Then it comes down to what body style do you want, and the front suspension..
