I'm using mustang motor mounts and I'm nut ache to slide anything over, did that when installing everything. Not running a body lift and I have everything as high as I can go before hitting the floor boards. Also my exhaust for my passenger side is in close tolerance to the frame so I can't shove stuff over any further. My plans are to instead cut the part thats on my way out and make it so that it goes up and attaches to the floor board via bolts and rubber mounting and proper reinforcing to the floor. That way no amount of flex well make the shaft hit any crossmembers.
My truck was done in pitch time so that's why stuff looks rigged up, but things will be redone and smoothed over next year.
Sent from my rooted SPH-D710 using Tapatalk 2
