fill plug on manual transmission
Jtjudd
8
Salt Lake City
Hey all - what is the fill plug on the manual transmission - it's on the opposite side of the fill and drain plugs
8,374
Jtjudd
8
Salt Lake City
thank you. I did remove the smaller plug as I thought this was the fill plug, tried to put some ATF into it - but it wouldn't accept the fluid - it would just ooze out. Did I do damage to the tranny?
Jtjudd
8
Salt Lake City
BTW - after draining the tranny - it took 2.5 quarts of ATF (Mercon 5). The old tranny fluid looked quite dirty and dark. I was surprised to not find any shavings on the drain plug
Josh B
1,988
Oklahoma
Not sure where or why but somehow I came up with
Pennzoil Automatic Transmission Fluid For use in older GM, Ford and other cars*
So how did I wind up with this?
Jtjudd
8
Salt Lake City
Thanks JoshB and RonD. I now know not to crack open the smaller fill plug on the tranny - but like Dork I did it and even tried to put ATF in it. Major league mistake. However - If an ounce of ATF got in there - what is the potential damage to the tranny? What is the smaller fill plug for?
Junk Collector
Truck of Month
4,870
Rapid City SD
The small bolt that you should not have removed keeps the 5th/reverse shift fork rod in place. It should be sealed in place with a bit of RTV or it will leak.
00t444e
217
Southern OH
Ranger ext cab
I take the shifter off and pour it in through the top, much easier, also Pennzoil Syncromesh works better than ATF.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,871
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
How would removing the shifter be easier than removing and installing fill and drain plug? My ‘98 and ‘11 are/were no where even close to being easier that way.
8,374
Easier because you can pour in the new fluid vs pumping it in
But I agree fill plug is right there so..............
Josh B
1,988
Oklahoma
Some folk like working laying down, some like workin sittin up
scotts90ranger
4,537
Dayton Oregon
2.3 Turbo
You had mentioned the bolt on the other side of the transmission, that's for the reverse idler gear shaft, you do NOT want to take that out as you likely won't get it back in...
As to your question, won't hurt anything as it's all in the same open cavity, there's just some things that aren't meant to be screwed with if you don't know what they are that is why it is clearly labeled Fill and Drain on the transmission case casting...
00t444e
217
Southern OH
Ranger ext cab
Because you can pour it right in, I fill all my manual transmissions that way.
scotts90ranger
4,537
Dayton Oregon
2.3 Turbo
The problem with that method is to do it requires pulling the shift boot, the lower shift boot then the 3 screws holding the seal on, in some instances that's difficult, on rigs like my '90 where the shift boot is held on by the rubber flex and gravity it's a non issue... I haven't put those 4 screws in in the last decade...
Josh B
1,988
Oklahoma
If you already have it open that is certainly the way to go. If it only needs topped up a bit use an old rear end oil jug for transmission, transfer case, and rear end. It will usually tilt right up and go right in, maybe sometimes needs an extra length of hose
